Chemical Guys Chemical Guys Maxi Suds 2
Discussion dans 'Snow Foam, Shampooing automobile' créé par Béhième, 5 Novembre 2011.
    By:Béhième5 Novembre 2011
    Super Modérateur
    Marque :
    Chemical guys
    Produit :
    Maxi suds 2
    Catégorie :
    Shampoing
    Photo :
    Description du fabricant :
    extreme suds all purpose Super Foaming Shampoo
    removes grim and dirt safely without stripping wax or sealants
    very easy to use in and out of the sun
    formulated with water softeners to reduce streaking and not leave water spots upon rinsing
    a premium state-of-the-art car wash that is not only extremely effective but also natural and gentle.
    non-toxic, biodegradable shampoo cleanser.
    Maxi-Suds II is a superior formulation of unique cleaning shampoos engineered to deliver unmatched cleansing power through superior cleaning shampoos coupled with a maximum release of cleaning foaming bubbles.
    MAXI SUDS II is an advancement in foaming technology works by suspending premium super polymers within a consistent discharge of bubbles allowing grime and built-up dirt to be effortlessly rinsed away.
    gentle cleansing agents, leaves your car sparkling clean, conditioned and protected.
    MAXI SUDS II creates an abundance of long-lasting, luxurious, aromatic bubbles, even in hard or calcium rich water
    high-performance cleaner, all purpose
    cuts through heavy dirt and road film
    biodegradable and phosphate-free concentrate
    1-Capfull Mixes with 1 gallon of water for washes
    1-Gallon Washes 60-90 Vehicles
    Cleaning Ability: Low 1 2 3 4 5 6 7 8 9 10 High
    Degreasing Ability Low 1 2 3 4 5 6 7 8 9 10 High
    Shining Ability: Low 1 2 3 4 5 6 7 8 9 10 High Scent: Cherry
    Maxi-Suds II SUPER SUDS SHAMPOO-Superior Surface Shampoo (1 Gal)
    The suds you want the shine you like!
    Maxi Suds II pH neutral carwash is ideal for daily wash as well as foam guns and pressure washers. The enticing cherry -scented car wash shampoo is pH-neutral and highly concentrated.
    The same professional grade soap used by car washes world wide is now available in a concentrated version for enthusiasts at home. Maximum Suds II Is a Extreme Suds Formula that delivers mounds of foam. Enriched with foaming agents that loosen and lubricate dirt safely and gently be rinsed away from the paint. With Maxi Suds II, duct, dirt and grime slide off the paint as you rinse with water..
    Full Description:
    Maxi-Suds II is a strong superior cleaning shampoo that delivers amazing cleaning results through a consistent release of right foaming bubbles. leaning Maxi-Suds II suds. Maxi-Suds II is uniquely formulated foaming technology. Maxi-Suds II works by suspending super polymers within each bubble allowing grim and built-up dirt to be effortlessly rinsed away. The unique lubricity of Maxi-Suds II loosens abrasive residue and allows it to be rinsed away without scratching the surface. The unique Maxi-Suds II formulation retains lubricity and will not all of hard water to remain on the surface hence causing calcium deposits and water spots. Maxi-Suds II rinses of clean leaving behind a clean shining surface.
    Even though Maxi-Suds II is tough against paint-damaging agents it is amazingly surface, wax and sealant friendly. It will not strip wax or any type of polymer surface protectants from the surface.
    great for mechanical and hand wash applications
    quick and easy way to wash any surface
    no hard rubbing and scrubbing
    great for maintaining already waxed car
    removes dirt and grime
    rinses clean
    easy to use
    Description du produit :
    Trés bon shampoing que l'on peut utiliser en foam lance ou dans des seaux, gros pouvoir nettoyant.
    MAXI SUDS II est un shampooing de qualité supérieur, offrant un très bon pouvoir nettoyant conjugué à une capacité de lubirfication exceptionnelle.
    Sa mousse dense et onctueuse permettra de faire tomber les contaminants par gravité, sans risque de dommages pour la carrosserie.
    La lubrification apportée par MAXI SUDS permet un rinçage facile, sans risque de frottement et donc sans risque de micro-rayer la carrosserie.
    D'un PH Neutre, il respecte non seulement les cires présentes sur le véhicule, mais également leur éclat puisque son rendu est neutre.
    Biodégradable, non toxique et sans phosphate.
    Mode d'emploi / application :
    Technique des 2 seaux ou foam lance
    En foam lance, vous le diluez et vous attendez 10 minutes puis vous rincez.
    Dilution(s) :
    Avec la technique des 2 seaux : 1:125
    En foam lance : 1:21
    Temps de pose :
    Tenue :
    Senteur :
    Cerise
    Avantages :
    Mousse beaucoup, wax-safe, idéale en foam lance mais aussi en seaux.
    Inconvénients :
    Il revient moins cher en gallon et en foam lance il nécéssite un additif comme le ph neutral snow foam de valet pro.
    Produits concurrents :
    Insta finish-maxi suds
    Le insta finish-maxi suds n'est pas seulement son concurrent, mais c'est l'identique.
    Le insta finish revient moins cher, mais dispo seulement en gallon.
    C'est à vous de choisir selon vos besoins.
    Disponibilité :
    Shinearama, france detailing.
    Ordre de prix :
    16oz/8€ Gallon/31€
    Conclusion :
    Un trés bon shampoing qui fera merveille, il va décoller la crasse tout en préservant la cire.
    5
    Liens vers des exemples :
    Pour le moment aucun, même si il y a quelques rénovation au Shine and Show.
    Si vous aussi vous avez testé ce produit, mettez nous votre compte-rendu !
  2. ailys
    By:ailys5 Novembre 2011
    [Fiche] Chemical guys maxi suds 2
    Super travail les fiches.
    Ce shampooing est un must have.
  3. cae
    By:caenautowash5 Novembre 2011
    23 Juillet 2011
    Volvo S60R
    Re: [Fiche] Chemical guys maxi suds 2
    je l'utilise en foam lance et il est tres bien en pre lavage , combiné à son frere " Wash and wax " c'est le top :super:
    Super Modérateur
    Idem que toi, je l'utilise principalement en foam lance, mon dosage 50ml de cg ms2 + 50 ml de ph neutral snow foam.
    Terrible ce duo et sa préserve nos cires.
    En revanche pour le wash & wax, j'ai lus qu'il modifiait le beading de nos cires ?
  5. Connect
    By:Connect5 Novembre 2011
    4 Novembre 2008
    Oué comme tous les Wash&Wax mais pas longtemps, il modifie un peu le rendu, le Maxi Suds non puisqu'il est "neutre". Le MS II est un bon shampoo, en revanche son pouvoir nettoyant n'est pas des meilleurs. Le Insta Finish est le même, moins cher en revanche.
  6. Nosman
    By:Nosman10 Décembre 2011
    23 Avril 2011
    Matthieu
    Re: Maxi Suds 2 [Fiche]
    j'adore ce shampoing, c'est un vrai plaisir de nettoyer son auto avec, sa mousse, sa sent très bon, sa lubrifie très bien, sa nettoie super bref je le recommande
  7. Vac
    By:Vac7229 Mars 2012
    13 Mars 2012
    E2220cdiw210 MeganeII Gsxr
    c'est mon combo pour débuter le détailing et je suis pleinement satisfait :super:
  8. Com
    By:Compte désactivé29 Mars 2012
    Maxi Suds 2 [Fiche]
    Merci de cette fiche.
  9. Nev
    By:Nevsky3814 Mai 2012
    16 Juillet 2011
    Une petite question
    Hier premiere fOis avec ce shampoo, technique des deux seaux avec 1:125 dans 5L d eau et jai pas eu de mousse, porche??
    By:Béhième14 Mai 2012
    Super Modérateur
    Tu as mis ton eau, aprés le shampoo et tu as mélangé le tout ?
    Ne pas avoir de mousse avec le MS2 c'est fort :|
  11. Nev
    16 Juillet 2011
    Exact cest ce que jai fait. L eau du seau est passee au rosee mais pas de mousse.
    Peut etre pas assez melanger?
    Super Modérateur
    Tu as quoi comme gant pour laver ?
  13. Nev
    16 Juillet 2011
    Un gant meguiars.
    Super Modérateur
    La prochaine fois mélange un peu plus car tu dois être le seul à ne pas avoir beaucoup de mousses avec ce shampoo.
  15. Vac
    By:Vac7214 Mai 2012
    13 Mars 2012
    Maxi Suds 2 [Fiche]
    As tu mis de l'eau chaude dans ton sceau ? Ça aide aussi
  16. thomasGTD
    By:thomasGTD3 Avril 2013
    2 Mars 2013
    Seat Leon FR Facelift
    thomas
    J'ai recu hier matin le fameux Chemical Guys Maxi Sunds II ( en plus d'autres produits) et je n'ai pas resister a le tester dès l'apres midi !
    Donc en prélavage au Foam Lance Karscher : Maxi Sunds II en 1:125 couplé au Valet pro Ph Neutral Snow Foam en 1:25 et le reste d'eau chaude.
    Résultat au top, une mousse dense et qui décolle toute la crasse !
    Puis J'ai continuer l'essai de ce shampoo avec un lavage technique des 2 seaux: 6L d'eau tiède + le MSDII toujours en 1:125.
    Résultat tout aussi impeccable avec un trés bon slick et une bonne capacité de néttoyage.(moins tout de mème que mon wolfgang auto Bathe)
    Donc pour conclure il est trés efficace en prélavage Snow Foam et tout aussi top pour le lavage mème si sa capacité de nettoyage n'est pas des meilleurs.
    PS: J'ai pu noter un affaiblissement de mon beading une fois la voiture rincée... alors qu'avant le lavage il etait meilleur ! Savez vous pourquoi ?
  17. alexgb
    By:alexgb3 Avril 2013
    29 Juin 2012
    Surement le shampoing qui laisse "sa patte"
  18. ailys
    By:ailys3 Avril 2013
    Le Wolfgang Auto Bathe (cf.fiche) est une tuerie.
    Mais ce MS2 est pas mal.
  19. **max**
    By:**max**3 Avril 2013
    16 Avril 2012
    206 Rc
    max
    Très bonne question!!! je m'en suis servie sur la 206 ciré en naviwax et comme toi le beading à pris un coup :amen:
  20. ailys
    Il n'est pas aussi wax safe que Chemical Guys dit ??? . . .
